whats up, my 89 legend just started being hard to turn every once in a while when i was stopped or moving under 5 mph. could it be my bushings wearing out or a pump problem?
peace,
jeff h.
Maybe your powersteering rack is leaking like mine. Just keep adding power steering fluid. Also does it make any noises? if so then you might want to check your lower ball joints. That worked for me.
Honda PSF!!
Check your Power Steering fluid and add Honda Spec fluid if low. Yes, it makes a difference.
Mine was leaking very badly and I bought a couple containers of Gunk Power Steering Fluid and Reconditioner for Honda and it really helped cut down the leakage. It still leaks a little but before, I pratically had to add fluid every time I drove.
