1 - 14 of 14 Posts
meber
I get in my car this morning and I decide to change the position of my steering wheel. I try to move it down and nothing happens. I can move it up, in, and out but not down. Any advice on how to fix this? Has anybody else had this problem?
has left the building
OK...
T, my '92 L only moves in and out. I've had the steering column completely out (dashboard replacement) and there is NO up & down adjustment. Maybe this is something that is peculiar to early L models. Anybody????
meber
Discussion Starter · #10 ·
Just a little more info. The steering wheel moves down when I put the key in, it moves down to the memory position but when I push the down button it does not move.
91LSMAN said:
I don't know what year is the cut off, but early models (91, 92) only adjust in and out. But later models regardless of trim leval adjust in, out , up and down. If someone wants to go into more detail, please do.
the cut off was 93. All 91-93 legend can only telescope (in and out) but not tilt (up and down)
All 94-95 can do both electronically via switches.
A lot of people answering questions, but not the original one that was asked, MCKell, you might have problem with the wiring, maybe in the switch, maybe a loose connection, somthin like that, caus its obviously not the motor that moves it up and down. its gotta be somethin in the switch. hope i helped
peace
Tnelson
1 - 14 of 14 Posts
