Originally Posted by gzagenius
to see if its your alternator
disconnect your pos battery cables while the engines running...if it keeps runnin the alt is fine, if it dies, well, then its not
ok disconnected the pos cable of battery while running, it kept running, reconnected the cable then shut off, went to start again, it wouldnt start unless i threw a jump on it. so could this problem be related to the wiper problem of the wiper fuse blowing everytime i put one in (instantly). is it possible that theres a short thats draining the battery that fast? and if so how do i locate it and fix?
