1 - 7 of 7 Posts
As noted above check out the online manual for directions, that being said the basics things to know:
1. There is a screw or two under each of the pillars that help hold the liner in place so you'll need to at least partially remove them. At the age of our cars there is a good chance you will break some plastic tabs.
2. Of course you'll need to remove holders attached to the liner.
3. The liner will only come out the front door with it fully open so make sure you have room for the door to be open plus another 3ft or so if you want the liner out of the way.
Here is a pic of it once you have the liner off:
Sun Roof Assy w/o Glass
Good luck with it.
You don't need to remove the sunroof glass to remove the whole sunroof assembly.
As stated above.
1. remove the trim pillars.
2. remove the headliner.
3. unscrew all the bolts to the sunroof assembly, and hold that biatch cause its comming down.
MAD DOG!
As stated above.
thats some good advice.... dont do the tilt mod unless your sure that you arent going to move the sunroof while on the freeway...
1 - 7 of 7 Posts
