1 - 11 of 11 Posts
yo, my sunroof decided not to work anymore on my g2 coupe, checked all fuses and they are fine, when i press the button it has like a clicking sound infront of the rear dome light.. think its a sunroof motor? lemme know... thanks
There are also 2 relays.
One for open and one for close.
Located at the rear of the roof.
From the manual pic, it looks like it is located at the rear dome light.
wish I HAD a sunroof:(!
No Sunroof? Dang dude...You are missing out..
Advice to people with sunroofs........keep the tracks cleaned with silicone and lubricated with spray grease. You will notice a dramatic difference in smoothness and speed of operation. This will also prolong the life of the motor.
suburban-noise: If you hear clicking noise, your relays and switches are indeed working. Sounds like it may be the motor, was it working fine before or was it slowing down? Anyway you can close and open it manually with the Allen tool in the trunk kit.
If you (or others) don't know
1. Remove the lens from the rear ceiling light.
2. Use a flathead screwdriver or coin to remove the plug in the center of the rear ceiling light to access the sunroof override screw.
3. Use the Allen tool to turn the override screw until the sunroof is fully open or closed.
4. Put everything back together.
-Good luck.
· Blk/BlkGS6
HELP!!!!!!!!!!!
MY SUNROOF IS LEAKING!!!!!!!!!!!!!!!!!!
it rained all nite last nite...........i get in my car in the morning and start driving...............and all this water pours down on me from above!!!!!!!!! i stop and dry off........and start going back down my driveway..........i thought it had all fallen.......................but then as the car goes down the slope, it just starts POURING down on me...................man that was so sh*TTY!!!!!!!!!
and the sunroof had been CLOSED...........................i tried pulling over the sunroof shade but the water kept coming through that too....................i had to take my moms car to school:(
anywyas when i got home i looked at it from outside, and..................the back edge of the sunroof looks like it has a gap between the window and the edge..........and i cud push it down with my hand................and it wud move down a little and create a bigger gap................so water cud fall through..........
MAN!!:(...............what can i dO? and how much will it cost?? any advice??
Me too!!!
I'm having that same problem.
When I park it nose downhill it don't fill so I think it's the rear drain holes are blocked. I'm going searcging for that thread on how to clean the drain holes.
FYI
There are 4 drain holes, can be cleaned by blowing compressed air through them.
Only Milk and Juice comes in 2 litres!
· Blk/BlkGS6
hmmm drain holes are blocked..............:confused:
so water is supposed to fall in through the sunroof on the outside but its supposed to be drained through the drain holes??
hmm i never heard that, but maybe i wouldnt know............so if thats it, how can i clean them? should i take it to a honda dealership or a mechanic or a sunroof shop??
how much $$, or can i do it myself?
it SUCKS, it rained again all day today!! i cant drive my car again tomorrow..........................:(
Drain holes ARE blocked
You drain holes are certainly blocked... I think I used a piece of a coat hanger to clean mine last time... I have had the same thing happen and once you clear the holes the problem will disappear! I think it is the fact that the sunroof does not seal 100% and water creeps in.
1 - 11 of 11 Posts
