Hey guys!
I recently installed Koni struts and Eibach springs on my 91 coupe. my right front is way higer than than the left side. I called Eibach they don't really have a solution to my problem, their suggestions to me was to swap them around by putting the right spring on the left and left on right side. I can't understand how this would solve my problem. any of you experienced similar problems? how did you correct it.
This is normal, All legends do this. the only way around it that I can think of would be Ground Control coil-overs, Or cutting your spring on the high side:( (But I wouldnt recommend this).
This may need to be moved to the "Performance, Mod." forum.
