Premium Member
There's 2 ways to run the power wire in your car, either find a grommet on the firewall that isn't being used and pop it out and feed the power wire through there, or carefully drill a hole big enough to fit the wire through.
Run the power wire down the driver side of the car.
Run the RCA's down the passenger side of the car.
You can either take out the rear seat to make the install easier, or just fish the wires under the rear seat to make it to the trunk, it helps if you have a friend in the trunk grabbing the wires.
Hope this helps.
