1 - 20 of 33 Posts
90Legendman(LS)
· Qualified Driver
Discussion starter · #1 ·
:mad: Hey everyone, I changed my temperature sensor yesterday. During the change I lost a decent amt of coolant, installed new sensor ( its the one under and to the rear of the distributor) replaced coolant, and now chk engine light is still on accompanied by the s3 light blinking:mad: Did I forget to do something? Is there a reset button somewhere?:mad:
Reset the ECU.
Pull the ALT SENSE fuse for 30 seconds and replace.
See if the CHECK ENGINE light returns.
Discussion starter · #5 ·
Pulling that fuse didn't work. Chk engine light is smilin in my face and so is S3. :mad:
From what I understand this is a temperature sensor, and the comp code is flasing 10 times which indicates intake temperature sensor. I'm hoping this is the right sensor that I replaced ????
Anybody have any clue ?
Intake temperature......makes me think it's an AIR temperature sensor, not a COOLANT temperature sensor.
The S3 light blinking would mean there is something wrong with the tranny?? The intake air temperature sensor is located right on the throttle body/intake manifold assembly, if that makes any sense?
Discussion starter · #9 ·
I found the intake temp sensor, right at the top easy job might take 2 minutes. Dealer is ordering one for me, will be here Wed.
The mechanic said its ok to drive with the bad sensor, I just hate that stupid chk engine light smilin at me like that:mad: and also the S3 light blinking:mad:
She also takes a little longer to start in the mornings. She turns over but then slowly idles then shuts off. I assume this is an effect of sensor, and occasional rought idling ??:(
Discussion starter · #10 ·
I finally installed my intake temp sensor after stripping the screw:mad:
The chk engine light is still on w/ the s3 blinkin and the computer still flashes 10 times (intake temp sensor). Is there more than one of these ?? Anyone, Anyone
check your battery, it might be high enough to crank but low enough to confuse your ecm. when my battery was gone it was just not strong enough to crank but both the check engone and s3 was on. take a voltmeter and make sure your battery and alternator is good. look for 12 volts when car is off and 14 volts when car is on. if it is under 12 - when off, your battery days are numbered
Discussion starter · #12 ·
I just bought a new Acura battery last month. I doubt its the battery now the alt is a small possibility. Christine also has trouble starting sometimes, it seemed to happen right after the chk engine light came on. So I checked the computer, 10 flashes ( intake temp sensor). I changed my fuel filter yesterday. Would the fuel injectors cause a starting problem accompanied by the chk engine light ??:(
Discussion starter · #14 ·
Ok I'll bleeding the system. Where is the bleeder screw ??
Would air in the system cause chk engine light and s3 to activate and annoy the hell out of me ??
Discussion starter · #17 ·
Johnny2 said:
Put the old coolant sensor back in, bleed air out of system & try it.
Yo Johnny2 you da man:bowdown: :bowdown:
I put the old sensor back in and now everythings back to normal, chk engine lights and S3 are both out and she starts right up as before. I'm assuming the new sensor I bought is defective, I will be going back to the dealer for a big fight to get my refund
Johnny2 said:
Yes, it will/can cause overheating.
thanks...ive been having overheating prob latly, though and might be a blown hg.
2 more thing.
1) whats the proper way to bleed the system?
2)if i find black floating thing in da side resovoir tank(seems like carbon) can that be a possibilty of bhg?
thanks in advance
1 - 20 of 33 Posts
