1 - 20 of 22 Posts
· I like shiny
You all know what I'm talking about right? That little piece under the ash tray and lighter? Mine is looking faded and dad's is torn. When the wood grain is removed is that piece removable? I want to try and "Re-wrap" it with another material and give it an updated, new look.
Oh and if anyone has a diagram of how to remove the center console wood grain piece, that would be great!!!
Has anyone done anything with that little piece?
it's been a while since i took my dash apart, but i want to say you can remove that piece, i think there are some screws involved once you take off the woodgrain. legend tuner has directions on how to remove the wood grain, i thing it's for a sedan, but probably the same way...
You can definitely remove the felt storage pocket from the console. If all else fails, replace it with a new one if it's not very expensive. Let me know what you come up with, I wouldn't mind changing the felt material to something else if it looked good. I find the felt gets dirt trapped in it very easily which gets annoying.
As far as removing the console, there are 2 screws in the felt pocket that you have to remove. On automatics, remove the black bezel around the shifter. On manuals, pull down on the shift boot to release it from the knob, the unscrew the knob. Then gently pull/pry on the console starting at the back to release the retaining clips. Just go slow and be careful not to crack it.
· I like shiny
Ok, thanks. I actually know what I plan to re-wrap them in already. I'm just going to try it to see if it works. I already have new material for the speaker grills so I plan to use the same material and double sided tape so it'll hold the shape. If that does not work, I'll try a different material, but that's what I'll try first. Hopefully I'll have time soon-we'll see!!!
· I like shiny
Discussion Starter · #9 ·
Thanks-just wanted to confirm that it is removeable from the woodgrain. I'm really hoping I'll have time this weekend for at least one of the coupes, but we'll have to wait and see. :D
Thanks All.
You'd think as often as I read this at Legendtuner for fun, I would have remembered they have that there. LOL
when removeing the center woodgrain, there are little clips that hold it down, well when you remove the woodgrain the clips have a tendancy to fall into the shifter area and are hard to get out, so you may want to have a magnetic thing(looks like an antenna but it has a magnet at the end) to get them out
· I like shiny
Discussion Starter · #11 ·
Thanks for the tip-I'll try and be careful if I have time this weekend.
1 - 20 of 22 Posts
