Dethred said:
A whole new design does not = better.
And he made 200whp after about 4-5 grand of work. When he got to an altitude where he could get higher density air the car shut off. Tyler's N/A sedan beat him in a drag race. Even if the setup were capable of 300whp its not usable in an automatic legend. Full boost (7.5 psi
) at ~4000+rpm? Not worth it. You do understand that he's had to of dumped at least 5-6 grand into the thing and is still slow? My point is 100% correct.
Engine management doesn't come with turbo kits because most kits that exist are for cars that have EMS piggyback systems within affordability. I wish DaveC would come on here, slap you, and teach you some common friggin' sense.
PS: Let me see some 400hp Maxima kits please.
FYI as per what I last heard, Tyler's car NA only ran about a 15.5. That's what a stock Type I stick runs. It's nothing special. Kyle's car was faster if he wasn't having the map sensor problems from his ghetto Joule turbo setup.
He made 225whp, get your facts straight or don't post. The shop that did his first setup left him with a buggy setup with many problems. They ripped him off for alot of money and not a well done setup. He spent his money though and it was a first step for getting the first working turbo g2 legend on the forums.
His new setup has nothing to do with that. He is fixing all of the problems and making his own kit to sell. The cost out of his pocket and mediocre results of the previous kit serve as a learning experience, and the benefits are passed on to you, and he fronted the cash for that. The reason the car shut off in lower altidudes is becuase of the map sensor/check valves not being set up properly and the stock ecu not being able to handle higher boost. Do you understand if configured properly it can work fine? Go read up on turbo hondas running on the stock ecu.
Not usable in an automatic Legend? FYI Tyler's Legend is automatic. So was DV8's when he ran the fastest Legend 1/4 mile time ever. The fastest drag cars are auto's. Do you ever think before you post?
@ Full boost of 7.5 psi @ 4000rpm" ? This was the ghetto Joule setup. FYI full boost at 4,000 rpm is not bad. Most turbo cars would be happy to have that. If you spool at like 2,000 rpm it is likely the power will die off uptop and the turbo will run out of steam.
"EMS piggyback" there is no such thing. You either have a piggyback on stock ecu, or an engine management system that replaces it. At least learn the basic terminology before you post. Turbo kits don't come with "EMS" systems becuase a turbo kit is just that. A turbo kit........a turbo, manifolds, and some piping. They can't include every upgrade YOU WANT for your car. NOT EVERYONE WANTS OR NEEDS A STANDALONE. Not everyone can afford it either. If turbo kits came with standalones and were several thousand dollars more, that many less people could afford them. They would sell that much less. Does a nitrous kit come with a bigger exhaust or engine management??
Whether you think so or not, the new design is better. Your point is incorrect and useless.
Please tell DaveC to come on here and slap me and teach me some common sense. You can listen to DaveC, he is the one who always put down the possiblity of a turbo Legend even happening becuase we don't have engine management. The rest of us who want to go fast can get turbo and be quick. It has already happened, and on stock ecu. Just like most turbo hondas are. If you want engine management, good for you, its the best option for optimal performance, and its available. But not everyone wants it, needs it, or can afford it. If you don't understand, making a kit is also about trying to re-coup the costs spent in R&D which he fronted out of pocket and come out with a profit. They need to SELL, and they will sell more the simpler and more affordable they are. The majority of the buyers will keep their motor stock and be fine with a decent gain and on stock ecu.
You are the only one making stupid ignorant statements here. Nothing I have said is inaccurate. I'm tired of correcting you and I'm outta here for now. Just keep your useless negativity to yourself along with your childish and immature name-calling, and wait until he posts his results and you will be proven wrong.
