1 - 1 of 6 Posts
remove the driver kick panel, and theres a wide wire harness, with a lot of wires, above the dead pedal, to the top of the fuse panel. make sure its plugged in snug. i think the flasher is below the harnesses. its kind of a tight spot, unplug it and then replug. you cant miss it theres more than twelve wires in that harness.
i pulled mine loose while installing factory fogs, and had your same senario. hope it helps.Mark
1 - 1 of 6 Posts
