1 - 7 of 7 Posts
Ok, check this out. In the past I've posted questions here on how to fix my tachometer because it only works every now and then. I was never able to fix it. Something new is happening now. When the tachometer is not working and I'm at cruising speed it feels as if the engine loses power then gains it back. It's hard to put into words. I'm going along and I swear I feel a loss of power almost like a light buck from the engine. It's noticeable is about all I can say. Anyway, when the tachometer comes back to life the symptoms I've described go away. What's going on?
Re: i'll check my manual...
mythical89 said:
sounds like a timing problem
i agree, my car had the same problem with the previous owner and he had the timing belt replaced and it runs great.
Well...
Are you sure it's timing if the symptoms go away when the tach works?
bump
Re: Tach does nothing!
leisureguy said:
I recently installed a set of indiglo gauges, and when i test drove it, my tach wouldnt move at all. I have no idea why. any ideas????:eek2:
did you check to see if the gauge is properly installed, i had that problem on my gauge until i noticed that the indiglo was a lil lifted cuzing it to hold the needle.
1 - 7 of 7 Posts
