When I got my GS there were so many little bulbs that needed replacing (the previous owner changed the cluster bulbs to red and there were a bunch burned out throughout the dash). The ONE thing I cannot figure out is WHAT ILLUMINATES THOSE LITTLE GREEN AND ORANGE SLIT LIGHTS that are above the Cruise Control Button, the Traction Control button, and the Rear Defrost button?
Insert key, crank, BHG.
Yea. The buttons around your cluster can be accessed by taking your under dash driver panel off then removing two screws that hold the cluster bezel in place. The bezel will pull out and the buttons are attached to that. Bring one to a dealer and they'll have no problem getting you a replacement.
