The throttle angle sensor is mounted on and driven by the throttle body unit. The sensor
is a variable resistor (potentiometer) that is used by the ECU to detect throttle movement
and position. A 5 volt reference signal is applied from ECU pin C13 and a ground signal
on pin C14. When the throttle is opened the sensor resistance changes which is read as a
varying voltage signal at pin C7. At idle position the sensor voltage is approx. 0.5V and
approx. 4.5 V at full throttle.
Code 7 indicates a malfunction in the throttle angle sensor or sensor circuit.
NOTE: This test requires the use of Acura sensor test harness part no.
07GMJ-ML80100 or equivalent. Wire colors referenced in testing procedures refer to
test harness coloring and not the actual harness wire color.
1. Remove Alternator Sense fuse in underhood relay box for 10 seconds to reset
ECU.
2. Start engine and observe diagnostic LED.
Flashes code 7 , proceed to step 4.
Does not flash , proceed to next step.
3. Malfunction is intermittent. Check connections between ECU and throttle angle
sensor. End of test.
4. Turn ignition off.
Image Throttle Angle Sensor Diagnosis
5. Connect sensor test harness between throttle angle sensor and harness
connector.
6. Turn ignition on and check voltage between RED and GRN test harness
terminals.
Approx. 5 volts , proceed to step 13.
Not approx. 5 volts , proceed to next step.
7. Measure voltage between RED terminal and ground.
Approx. 5 volts , proceed to next step.
Not approx. 5 volts , proceed to step 9.
8. Repair open in GRN/WHT wire between throttle angle sensor and ECU terminal
C14. End of test.
9. Turn ignition off.
10. Install test harness between ECU and harness connector. If test harness is not
available, carefully backprobe wires at ECU connector.
Image Throttle Angle Sensor Code 7 Diagnosis
11. Turn ignition on.
12. Check for voltage between ECU terminals C13 and C14.
Not approx. 5 volts , replace electronic control unit. End of test.
13. Measure voltage between GRN and WHT wires with throttle full open.
Approx. 4 volts , proceed to step 15.
Not approx. 4 volts , proceed to next step.
14. Check for short in RED/YEL wire between ECU terminal C7 and throttle angle
sensor. If wire checks OK, replace throttle angle sensor. End of test.
15. Turn ignition off.
16. Install test harness between ECU and harness connector. If test harness is not
17. Turn ignition on.
Image Electronic Control Unit Pin And Connector Identification
18. Check voltage between ECU terminals C7 and C14.
Approx. 4 volts , replace electronic control unit. End of test.
19. Repair open RED/YEL wire between ECU terminal C7 and throttle angle sensor.
