1 - 8 of 8 Posts
I have recently been having problems with my throttle position sensor witch is located on the throttle body to replace this I have to buy a whole new throttle body. Does anybody know of any web sites that sells performance throttle bodies for my 91sedan:D :D
well, MLS does sell big thorrle for Legends... Just that you have to find a way to get them from Japan:rolleyes:
Junior Mint
I think the factory throttle body is bigger than 62 mm. More like 70 mm if I remember correctly.
0000$$$$0000####0000
Technically you do have to get a new TB, but a while ago, Eric Wong had a spare TPS sensor as what he and his mechanic did was cut a slot into the smooth bolt head that holds the TPS in, and then simply used a slotted screwdriver to back the screw out. He was selling a new TPS sensor last year some time since that turned out not to be his problem. But anyway, I'm not sure how he was able to get an independent TPS sensor in the first place.
1 - 8 of 8 Posts
