Kevin, 235 or 245 would be too wide - you would experience some scrubbing. Why do you want a wider tire? 225 is perfect with that offset and width.KTD said:I have 18x7 +42 mm rims w/ 225 40 18 tires.
I wanted to know if I can get wider 235 or 245 to fit?
kevin
ditto!RenoG said:What in the world is a rim protector edge? please explain.
and no a 225/40/18x7.5 +42 offset will not rubb nor does it stick out its flush with the fenders. Thats what I have.
basically like a wheel "cup"cdndvl said:A rim protector edge is a thicker rubber part of the tire, near the bead, that sticks out a little past the wheel edgeand protects the wheel a little bit from damage... I'd have to post a pic to truly explain it...
