1 - 20 of 28 Posts
AKA Carlton I3anks
Tom asked me to post this since hes at the shop slving while SR5guy sleeps:hide:...
Mods:
Type2 heads
Type 1 intake manifold
type2 cams
BHG!
5SPD
Everything else basically stock......Still put down 198whp!
actually, that run was 199.41, the best of three. the first run was 198.61, the second was 199.38. oh i also have an sr5guy stage 3 chip.
AKA Carlton I3anks
Basically 200 to the wheels w/out headers...Very impressive If I must say so myself also considering its not a "true" Type2, its a type 1 3/4.
The Infamous Left Lane
:lol:.... Good job tommy boy nice numbers and reppin the bhg club heavy noice..
Una Leyenda
that is impressive, you are definitely taking me there next time i go!!!, i'm going this coming monday before i wake up one morning and not find my car lol
AKA Carlton I3anks
Discussion Starter · #19 · (Edited)
I can't wait to get back into the Legend world again...Im coming back with a vengence!!
On another note LOL, Tom you put up damn near the same numbers as this:
Long Block:
- Fully rebuilt Heads
- 3-Angle Valve Job
- Shaved head/block
- New main bearing
- New rod bearing
- Machine Honed
- New rings
- Crank/egnine rebalanced
Exhaust:
- OBX headers, Ypipe
- Strömung Exhaust System
Engine Bolt on's:
- Labrat Lightend Pulley's
- Blackend Motorsports Engine Damper (with upgraded Poly bushings)
- Toyo Roki NSX tall oil filter
- Royal Purple Engine oil
Engine Management:
- Telion StageIII tuned ECU
Brakes & Suspension:
- Ksport Coil-overs
- MLS Strut Bar
- Fut's Rear Tie bars (short and long bars)
- Addco Rear Sway bar
- LGND rear sway bar endlink bolts
- SPC front camber kit
- Ingals Rear camber kit
- Brembo Blanks
- EBC Yellow pads
- DOT4 brake fluid
Transmission/Drivetrain:
- StageI Exedy Clutch
- Resurfaced Flywheel
- RangerJoe Short-shifter
- DOT4 Clutch fluid
- GM SynchroMesh MTF
- Royal Purple Gear Oil (diff)
LOLLO,OL0LOL..Tom im starting to beleive your BHG stories are B.S.! lol You saved your NALM money for a 3.5 swap, smart man:thumbsup:
Premium Member
LOL damn, now I wanna get a dyno run in. I'm curious what i'm making with Matt's Stage III chip, CAI (gotta get my new fender liners first), Type I y-pipe, and axleback exhaust.
1 - 20 of 28 Posts
