i'm getting code 8 off my ECU but when checking my timing its lining up with a strobe, could this just be a sensor failing or is top dead that sensitive that it might be off just a hair?
B
B
That would explain why it takes a few seconds and sometimes a few trys to get it started, huh?The TDC sensor is only used during startup and can sometimes cause a no start if the sensor is completely dead. The only way to fix the code is to replace your distributor (junkyard is your best bet... throw on a new cap/rotor and you'll be good to go) as the TDC sensor cannot be replaced separately.
Timing with the engine running should be on because the crankshaft position sensor is providing accurate data.
Yea me to manI'm getting the same code too. I guess I gotta look around ebay.
You managed to take it apart and install a new bearing? I thought our distributors had issues with that and it was impossible to get the TDC sensor to align up again?$4 bearing or $200 distributor, your choice.
