1 - 16 of 16 Posts
Yeah just hit him up, i'm shure he'll tell u where he got what he did.
my 93 six speed has one
my 93 six-speed has a trans cooler and oil cooler from the factory. i am not sure about other five speeds. there are hard mount lines in the bottom of the trans that go to rubber lines and then to the front to a cooler. check it out see for yourself.
B**k F***er
93TypeII: Every Legend has a stock tranny cooler located in the lower portion of your radiator.
In addition to that I installed a B&M 6"x11"x1.75" cooler. I went with B&M because they are a well known brand and the price was right with the installation kit ($55). I bought it from Summit Racing back in November. You splice it directly into the hoses 93TypeII is talking about. With the install kit they give you ~4' of hose to work with, clamps, mounting brackets, etc. to get the job done. It's a good do-it-yourself job :)
I have a few pictures of it installed in my car:
http://demandred.dyndns.org:3000/Legend/albums/album13/aac.jpg
http://demandred.dyndns.org:3000/Legend/albums/album13/aaa.jpg
jose3030 said:
i dont have a tranny cooler.
but i have a cooler tranny than you.
it's a 6speed.
<-- *****mode.
Bastard:D
B**k F***er
It comes with basic instructions for getting it into the cooling system. You have to figure out how to mount it. The kit came with these plastic tie-wrap type things with flat surfaces. I ran them through the a/c condensor, inbetween the fins and right through the screw holes of the tranny coolor. They come with small pads to pad it against the coolor so it also sits about 1/8" away from it as well. Very easy to install. I replaced my radiator at the same time so I would imagine if I did just the tranny cooler it would have been 1-2 hours of work.
1 - 16 of 16 Posts
