OK.skip said:I have A '90 legend L Auto, and a similar problem.
If I don't warm her up for a long time, it won't shift up to 3rd & 4th gears.
Also if I drive it while it's warming up (only uses 2nd) at some point it will rev up, as in Neutral, but this will only last a few seconds at most, then it shifts up and runs great (I usually let off the gas for several seconds, then tap the gas, and it will be ok).
I Changed the fluid (3X) shortly after I bought it (about 170,000 mi) to clear out the fluid from the tourque converter, etc.
It has done this since the day after I bought it. It now has about 185,000 mi.
Any chance it could be a solenoid, or sensor, or are the clutch plates the only likely source of the problem??
Anyone else out there have any info - advice..?
Also in looking for used trans (and other parts) I find 86-89, and 91-95... ? Is the '90 "special" or the same as 86-89?
I checked the Transmission code
I got 1 long blink, then 12 blinks (that's a 12, right?)
On the chart from the other threads I've read there is NO 12 (1-11, 13-15...)
Anyone have any idea what's up with that?
Am I reading it wrong?
Appeciate any advise with this.
