Hey guys i have a 91 legend 4 dr. I was following the diy.. section and i ran into a problem. the red wire that matt says to put into the dimmer control does not put on the reverse glow gauges the regular lights just come on. SO which plug can i stcik that red wire on to get power. plz help thanks again. ASH
hey... the dimmer switch is a b!tch to use.
connect the red wire the radio fuse. the radio fuse is located under the kickpanel. It will work then.
If you want to dimmer control on you indiglos... you have to connect it to the heater button (above the dimmer button). it's one of the red one's I think
