Timing Belt & tensioner
Water Pump
Change All the belts
Spark Plugs
Transmission Oil Purge
Brake Fluid drain and refill
Radiator Drain and refill
Power Steering Fluid drain and refill
Check brake pads, replace if necessary
that's all I can think of right now! Hope this helps!
At 150K you do a 30K service. Your last tune up (i.e. plugs) should have been done at 120K. So all you're due for now is air filter, oil/filter, trans and differential fluid.
I think no matter what, It all depends when work was done. For example if the the timing belt was done @ 60 than the next one should b @ 120 BUT if the timing was done @ 90 than the next should b @ 180. The maintenance book has a middle sheeet the recommends wot should b replaced and inspected @ a specific mileage, IF the timing belt was done @ 90,000 miles.
Latin.................
