1 - 6 of 6 Posts
I don't have any pics, but the my tweets are mounted on the little triangle part (the backing of the side view mirror) and the wire just taps down into the regular speaker wires. I'll be buying a crossover later. But I guess you could say this is the ghetto way of making a 3-way componet. But hey, it works pretty well.
I flush-mounted mine on the top corner of the door panel, under the side window fog vents. Sounds and looks okay...just be careful when drilling the tweeter mounting holes for anything underneath. I had to remove the channels for the side fog vents (so now the vents don't work, I had to clog the things up).
You probabally should mount them on the sails (like 894door did), or flush mount them above the woofer area (if your tweeters are directional and can be pointed at your "front stage").
What I am gonna do for my tweeters(hopefully soon) is to surface mount them where the o-sh*t handle is on the front. I took off these handles already beacuse they annoyed me and I filled the lower holes with some plastic that matches the tan color of my interior. You can then surface mount them over on the top. They are up out of the way and both of them have the perfect angle. Just an idea.
1 - 6 of 6 Posts
