Jim V, if the RSX is the same as the previous Integra as far as wheel size it won't work the lug spacing is 100. But I'm still checking for you to be sure.
I'm pretty sure (but not positive) that the bolt pattern is correct. But I don't know if the offset is appropriate, or if the center hole is large enough.
My dealer didn't seem to want to help. I did just find a site that said that the RSX wheels are 16" x 6.5", 5-115 bolt circle, with a 45mm offset - no info on the center hole diameter. Anybody have any additional information?
TIA,
Jim
Center bore for all Honda/Acura will be smaller than that of the Legend, execpt for RL which I'm not really sure, but no one wants RL rims anyway.
Legend bore: 70mm
new Honda/Acura bore: 64.1mm
So you will need to bore the center bore of the new Honda/Acura rims to 70.1mm at a machine shop to make them fit properly. Boring at a shop runs between $50-$150 depends on where you live.
The Legend bolt pattern is 114.3 x 5 and offset is 65mm and the rims are 6.5 inches wide.
1 - 8 of 8 Posts
