1 - 20 of 25 Posts
And my MLS strut bar is here. Let me tell you it makes a noticeable difference.To the guys who already have it do you have problems with the hood not wanting to shut all the way? I mean it shuts but my hood isnt sitting flush against the fender:confused:
Junior Mint
No problems with fitment.
Was this from the Dale groubuy?
same as EK
Discussion Starter · #11 ·
Basically I took of on each side 2 bolts. I then had to work on the bar onto the suds. from there I just bolted down the bar. It is poking holes into my ood liner and my hood I have to put xtra effort to close it.
what did you pay for the strut bar? did you get it ordered from JP?
does the bar push on the hood when you do sharp turns?
Discussion Starter · #14 ·
LegendGS said:
Does it look like this? The mounting studs should include the one closest to the engine, and the one closest to the firewall (actually, as I remember it, the strut bar should only go on one way anyway).
Yeah just like that. Did you have to play with it to get it to fit? I did.
I went thru another source and yes I did get it from Japan. I paid about 225 and had to wait 3 months(only because other parts he ordered were backordered)
Junior Mint
225 is a great price, can you tell us your source?
Make sure it's the strut bar for the Legend. Maybe there's a mistake there.
Discussion Starter · #19 ·
rockshox72 said:
Do the struts themselves have to be removed to install the strut bars, or is it just the bolt that your undo? Is there anymore groupbuy going on for these?
Upi just remove 2 bolts on each side. Ask LegendGS about the gb. I believe its over. I will get the email for my source when I get back from a meeting.
Anyone know why my hood still sticks up? Any thoughts
0000$$$$0000####0000
Have you figured out the problem? I'm having the same problem as you are with the copy MLS strut bar on my Coupe. Also, is your car a Coupe or Sedan? It seems like the Sedan guys are not having any problems, although I can't see any differences under the hood, so it could just be coincidence
1 - 20 of 25 Posts
