By the way, the reason why I gotta do that trip today is my family is leavin the country and we gotta catch the plane
There's no such thing as a dumb question be cause nobody knows everything. But I wouldn't worry about it as long as it's running right. Just stay on top of maintenance and the car will be fine.what can happen as worst?
Does engine gets just blown or something immediately?
I'm sorry but I have no idea what those cars can do, that's why I keep askin dumb questions![]()
Under the carpet in the front passenger footwell is your ECU. There is a small service connector plug that is above it. Jump it with a paper clip and turn the ignition on (don't have to start it). Count the number of blinks that you get from the check engine light. Short blinks represent 1-9. Long blinks represent 10.
Come back here with the code, and someone here will tell you what's wrong.
Ok so,1. Locate ECU Connector
Pull back the carpeting on the passenger side footwell, under the glove box. Locate the service check connector. It is a two-pin female connector, with black and white (91-92) or black and yellow (93-95) wires. It may be plugged into its cover on the top right of the ECU.
