Ok, here's the problem. My ALB Modulator unit is overflowing at the resevoir cap and leaking onto the ground and the fluid level is dropping from my master cylinder resevoir.
Eventually the fluid level drops low enough in my master cylinder that my brakes sink right to the floor. Now I brought it into the dealer and they say I need a whole new Modulator unit and also a new Accumulator pressure switch. They want $1500 CAN for the Modulator and $365 for the accumulator/pressure switch. They say that a faulty pressure switch might have damaged the modulator and that I should replace the pressure switch too or else it might damage a new modulator. They say there is no way of knowing what exactly is wrong with the modulator unit and no way of knowing if the pressure switch/accumulator is even faulty. They also say there is no way of fixing the existing units (aren't there any seals/bolts/gaskets they could tighten??).
Now, has anyone else had this problem or have any information that might help me here? Also, what would happen if I pulled my ABS fuse? Could that diable the ABS system and stop the modulator from overflowing? Please, any help would be greatly appreciated.
