kotetu said:
OK guys, here is what I have found out:
The car has 94k miles on it. /thumbs up
The car has a dent in the d/s rear quarter panel, ugly but not horrible /thumbs down
The car has a shot VSS /thumbs down
The car has a good A/C compressor /thumbs up
The car has none (or misplaced) records /thumbs down
The car moonroof glass is cracked /thumbs down
I gtg, I'll add more later. Comments?
Ok, I'm back. Here's the rest:
The car has a shot door lock actuator (click click click click click!) /thumbs down
The front seats (particularly the driver's) are very worn /thumbs down
The shift boot is dead as a doornail /thumbs down
The handbrake button has 1/2 of the chrome torn off /thumbs down
The auto-up/auto-down feature of the driver's window doesn't work /thumbs down
The driver's visor is broken off /thumbs down
Apparently the temperature gauge is acting weird (temp rises sharply, then drops down to normal at odd times; it is inconsistent) /thumbs down
It has a Sony mp3 player with speakers and sub /thumbs up
The speakers hiss something ugly! /thumbs down
Driving test
The car drives like a CHAMP. No hesitation, no shuddering, etc. It's pretty darned quiet, and has great power and acceleration. The exhaust (aftermarket muffler) is a bit loud, but sounds fine. I noticed no problems with acceleration, braking, steering, shifting, or anything else.
Other than the cracked moonroof and the small dent, the car looks great on the outside. The inside is marred by the worn seat, shift boot, hand brake, and missing visor.
Now, the seller is looking for the records (he thinks he has them in a file somewhere in his house) and I'll find out if the timing belt/water pump were done. (In fact, I'll find out if the 90k was done.) The only issue I am concerned with that can't be simply diagnosed (afaik) is the issue with the temperature gauge.
Someone mentioned that that could indicate a BHG, is that truely the case? What can confrim that this has happened?
thanks again!
