1 - 7 of 7 Posts
has anyone themselves cut that compartment in the rear deck to vent the trunk? i was thinking about doing it and wondering if anyone else has. Also does anyone know where to get speaker grill from to put over the hole? thanks alot.
--cody
In my current sub project I just cut a whole in the back deck- a big one at that. You can use tinsnips to do it but it makes a lil messy edge. You can get a wooden frame or something and just cover it with cloth. Good luck with that.
· 0000$$$$0000####0000
I cut directly under the center pocket for my 10" AP sub system. I'm not done yet, but I simply used those hand held sheet metal snip things. I did have an electric one, but the rear glass and the size of the tool made it easier with the hand held tool. That was for the rough cut. I used a dremel tool with the appropriate cutting bits and sanding/grinding bits to smooth it out. I'm not even 100% done doing that :( I haven't had a chance to add a speaker grill over yet, so I can't offer anything there. The metal is fairly thin, so it is not hard to cut at all.
i used and air saw to cut a 5 in hole under the campartment in the deck. then i ripped the compartment out but left the frame of it alone. after that, i went to radio shack and bought speaker grill cloth and wrapped the frame up. lookds really good. as far as functionality, i don't know if it made any difference because i'm running the subs in a sealed box. i know it makes a big differenct in a ported box though.
-j
1 - 7 of 7 Posts
