Water In Car
766 Views 1 Reply 2 Participants Last post by  Sandwichmaker
Good Evening,
I have a 95 Legend for the past few weeks after it rains my front passenger seat is wet the carpet the underneath the seat is SOAKING wet and also the rear carpet is wet as well. Any help will be much appreciated.
1 - 2 of 2 Posts
The most common cause of water entry is blockage of the four sunroof drain tubes with dirt and leaf debry. These tubes channel water which gets past the sunroof seals through the pillar areas of the car down to exit tubes near the tires. If you can locate them, you can take a stab at clearing them from the bottom. I've used weed wacker plastic line to do so. There is more information on this forum discussing this topic in detail.
  • Like
Reactions: 1
1 - 2 of 2 Posts
