I have pictures, but need to take a few more and those will required that I take off intake which I wont have time to do until Friday. Please read through this completely before you do anything to get good idea what is going on. This is a preliminary DIY until I have time to add pictures and restructure the instruction, add proper names of parts etc.
First remove the clamps on the oem filter, then the hose (the size are different so its easy to match up with the weapon-r). There are 3 bolts to remove to take out intake box (I am going by memory so I may be off by one), one of which you get to by removing the oem filter, the other two are closer to the engine. Take out oem box, clean area you are going to attach coupler to (those grey rubber things, both couplers are same size so it not matter which goes where). Use clamp to attach the coupler to throttle body (is that what it is called?), insert weapon-r intake (the bent end) to coupler, use second clamp to secure it. Attach the 3 lines to matching port on intake (use on supplied with your system, you may want to hold off cutting them shorter until you test the system).
Attach to other end of intake the other coupler secure with clamp. Get that bracket (supplied with your kit, has a curve on end and many holes/slots) and slip it between clamp and intake filter and other end of coupler. This will act as your support (I did not install this as yet, going to do so this week end and will take pictures then). That rubber thing with a bolt going through it goes into one of the holes bellow the intake and than you need to bend the metal bracket so that a hole lines up with the other end of "bolt" in that rubber thing (sorry I don't have instructions with me, cannot remember what they called it). You want to bend it at a point where the metal bracket will support the intake and keep it from touching/resting against anything. Secure metal bracket with supplied nut. That should be it. Oh for the time being go to page 3 of the "Weapon R Secret" tread bellow for a few pictures posted by LS92Sedan.
