Connecting rods connect the piston to the crank shaft. When the pistons go up and down, they move the rods which in turn move the crank.
There are two sets of valves on a head: intake valves and exhaust valves. The intake valves open and let in fuel/air, the spark plug causes the mixture to explode, then the exhaust valves open and let the fumes out. Then the process starts all over again.
Check out http://www.howstuffworks.com/engine.htm Very good stuff.
