what's up everyone.
i've posted b4 but not for a while. this is a great post. if i have a question b4 i post it's been asked and answered.
anyway, i have a 1991 sedan which i bought from a retired lady (original owner) in rockland county, ny. she took good care of the car. she gave me all records. (she bought a 2002 toyota avolan)i bought the car on march 1, 2002. i've done some work maintenance most of it. here is the list including original owner work:MY 1991 “ACURA LEGEND” 4 DOOR SEDAN REPAIR RECORD
ALL SCHEDULED MAINTENANCE DONE…
05/09/91-Replaced Shift Cable (RECALL)
05/12/94-Replaced Alternator
-Replaced Throttle Body (RECALL)
04/18/94-Replaced (Engine) Interg. C/Unit
-Replaced Heater Control Panel
0401/94-(Engine) Oil Pressure Mechanical Switch Replaced
06/13/94-Repaired Electrical Loose Wire Near Gauges
10/1997- RECOMMENDED (Cat Heat Shields) REPLACEMENT, DECLINED
10/24/97-Replaced Radiator
09/23/98-Rebuilt Vehicle Speed Sensor
11/05/99-LEFT AXLE REPLACED
01/10/00-Replaced Fan Switch
09/14/00-PART OF 90,000 SCHEDULED MAINTENANCE DONE.
12/19/00-90,000 SCHEDULED MAINTENANCE COMPLETED
-BELTS
-WATER PUMP
10/11/01-Replaced Water Hose
08/27/01-Installed New Drain Plug
04/05/01-Replaced Thermostat Incorrectly
01/08/02-Re-installed New Thermostat Correctly
AFTER I BOUGHT IT:
03/16/02-LEFT AXLE REPLACED
-New Radiator Cap
-REPLACED PLUGS
-REPLACED FUEL FILTER
04/29/02-Brakes (Wagner)
-Cleaned THROTTLE BODY(SPRAY)
05/18/02-REPLACED LEFT BALLJOINT
-ROTATED TIRES AND ALIGNED (4 WHEELS)
BRAKES
12/19/00-Rear Brakes Pads
09/14/00-Front Brake Pads/Rotors
04/29/02-Front/Rear Brake Pads (Wagner)
STILL NEEDS:
CHECK A/C SYSTEM
COILS/STRUTS
i got the car diagnosed on 06/10/02. Everything checked out fine. i thought the rpm's were low, but its btwn 650-700 so its ok according to manufacture specs. one thing anoying me is that the motor shakes a little too much. when the car is all warmed uo on d4 a little, park more noticeable. but like i said diagnostic showed everything tiptop shape....
Any ideas? can bad motor mounts cause this?
oh!, i also got my oil changed on 06/10/02. i noticed they used penzzoil 20/50. how good is this oil for my car (104,000).......
thanks
1991 Legend Sedan
mesh grill
cashmere
rest stock
I would think if it were something serious they would have noticed it and brought it to your attention, usually when you take your car in for a Diagnostic check they look for things that they can service for you to make more money off you. How bad/noticable is the shaking? Is it making any noices at all? klunks or clicks, thumps etc?
