Neutral.jigga622 said:i heard 1st and i've also heard second...disadvantages or advantages? thanks
After the car comes to a complete stop, I use the hand brake first to stop and settle down the car then engaging the clutch in 1st gear. It's just a habbit, I guess.jigga622 said:i heard 1st and i've also heard second...disadvantages or advantages? thanks
TAHT IS EXACTLY WHAT I WAS GOING TO SAY!KNLNGUS said:I would say eddie response is applicable to all automatic and manual vehicles.
It pains me to see someone park on a hill and then they slap the bi~atch in park and the car rocks back and forth. And then you will hear them cranck down on the ebrake. I do not pretend to know what stress (in a automatic) that is action gives the internals but I can tell you it does not look good and...
In a 6 speed I would say this action would stress the flywheel first and that would be the majority of movement followed by the internals of the differential because with a gear engaged... the play or free movement will most likely be the result of the differential output shaft wear and differential box wear.
In a 5 speed you would stress the sprung friction disc and then the internals.
KNLNGUS
Yes, that's the best way to save wear & tear on the parking pawl mechanism. Just because we shifted into Park does not mean all is well since it still has to find a spline to latch itself onto.KNLNGUS said:I would say eddie response is applicable to all automatic and manual vehicles.
Enlighten me if you will, but I think the clutch assembly & flwheel would be spared of any abnormal wear & tear (aside from slipping into a tight parking spot) regardless if it's a 5sp/6sp car.
KNLNGUS
Clearly that's not what damages the flywheel, right? Since the disc is always pressed against the flywheel even in neutral.KNLNGUS said:HOWEVER - I will say that when there is no pressure applied to the clutch pedal your clutch friction disc is fully compressed by the splines or fingers of the pressure plate ON TO the flywheel.
KNLNGUS
Yep that's perfectly fine assuming that the motor has good compression and doesn't have a slipping clutch.Bobchad said:For a manual transmission, 1st is the second choice with reverse the gear of preference. The whole purpose of doing this is for safety in case of brake failure. It will allow the compression of the engine to hold the vehicle in place. The lower the gear, the stronger the hold.
Bob
If you have these two problems I guess you are SOL. It's still better than nothing and about the only thing you can do.Nathan_Rd said:
Yep that's perfectly fine assuming that the motor has good compression and doesn't have a slipping clutch.Anyone with dubbs care to share their curbing experience.
St. Peter - "How did you die?"Bobchad said:
Anyone remember Bill Cosby's monolugue about learning to drive in a VW on the hills of SF. Well that was me.
Bob
