hey guys...okay. i'm sure this has been covered numerous times, but i think my situation is different. my auto down drivers window. it works,then it doesn't work. then it works again, then doesn't work. i can say that it works consistently when the weather outside is hot, like 80 degrees or higher. otherwise it doesn't work. anyone know what's wrong? someone help cuz this is pissing me off. thanks.
You need to check for corrosion in the Male/Female connectors of the Door Wiring Harness to Body Harness. There is also a Pulser which could be failing. When the problem occurs do you lose the AUTO Down feature? You need the applicable pages from the HELM to test the Master Switch and Pulser. The HELM makes no provision of a decision-tree for intermittent problems. The next time this problem occurs, test the window operation with the door fully open as well as closed in order to possibly rule out a wire harness break. Intermittent problems are frustrating.
