Guest
·I have a 95 L Coupe w/ 59K on it and my rpm is about 3500 at 80mph is this ok?
Change the tranny fluid a few times, w/ Honda ATF, then test it out again, what do you think?Thai.95LCoupe said:yah my Coupe is an auto... If the RPM is high what could be the problem..
-Jose
Yeah i'll probably have to wait until May when I come home to do that...LeGeNdZ_4_LiFe said:Mine is around 3150 Thai - Type II
May want to have the 60k service done.
why would it matter? the speedo is calibrated to the stock tire diameter. so if he put smaller or larger diameter tires wouldnt make a difference when the speedo gear is turning the set speed for 80mph. all the tires change is the ACTUAL speed...right?Bukowski=Legend said:KenS hit the nail on the head.
It is totally dependant on your actual tire diameter vs. what stock actual tire diameter size is.
If your taller than stock, less rpm, if your smaller than stock, more rpm....
I'd compare a stock size to what your running before I assumed anything was wrong.
Talkin rpm not mph. RPM is based on total gearing. Actual tire heigth is part of the final gear ratio.RICDOGG said:
