1 - 11 of 11 Posts
Could whoever has upgraded rims and feels like it share this information:
- Coupe or Sedan?
- How large are the rims and what size are the tires?
- What kind of rims are they?
- Is your car lowered, if so, how much?
- Do you experience rubbing?
- What offset are your wheels?
This one is for aesthetic purposes:
- What is the diameter of your wheel and sidewall, from one edge of your tire to the other?
Thanks in advance...
J520
Here's a list of all the setups that I have runned so far.
94 Coupe
Current setup.
19 x 8 with 235-35-19 Pirelli P7000 Summer
Racing Hart M5
Offset is a +51
Chrome Momo Idea 17 x 7.5 +49 offset-215-45-17
Racing Hart Type-C 17 x 7.5 +40 offset-215-45-17 (slight brushes in the rear)
Chrome (NDP) SSR DeColte Evolution 18 x 7 +49-225-40-18
Lowered about 1.5" with Koni and Eibach springs
No rubbing at all
· Senior Member
Re: Re: What kind of rims do you have?
94 Coupe
Current setup.
Racing Hart M5
Offset is a +51
No rubbing at all
Damn... hey TypeII, you got any pixes of your current setup?
Re: Re: Re: What kind of rims do you have?
Not really, all the goods picts have not been downloaded off my DV tapes, something is wrong with my Firewire cable. Here's a lousy one in the meantime. It's a pict of two of my cars.
· 502MotorSports.com
- Coupe or Sedan?
both
18" 225/40
Enkei (before) Shuriken, (current) QT s-11
Coupe - 2"/1" | Sedan - Stock
Coupe - ONLY with the Enkei on EXTREMELY Hard turns w/ subs and full load in the rear. (+40 offset)
Sedan - With the +42 offset QT's - no rubbing, even with U-turns
NO rubbing at all any condition (+42mm offset)
Sedan - rubbing on sharp turns and with full load (+40mm offset)
currently 18 x 7.5 +42mm offset
before
18 x 7 +40 offset
· 0000$$$$0000####0000
93 LS Coupe
Lowered about 1-1.25" in front, and about .5-.75 in the rear.
Camber corrected back to 0 in front, and rear.
Rims are Manaray Sport MS-6 Hyper, or it might be M-06 Hyper I forget :)
They are 17 X 7 with a +46mm offset
Tires are 225/45/17 Potenza RE 730
Front is about 1-2mm tucked inside the outer front left fender.
Front right tire is about 0-1mm outside the front fender.
Rear tuck in very well.
Have occational rubbing under very hard corning, but very rare.
Here ya go
Sedan
Nippon Racing Version II's
17x7 with 215/45/17 Khumo Ecstas
+42 offset non-lowered
Hmm.... I should learn how to insert an Import model. She would do my car justice rather than me. :D
My setup
Sedan
17 x 7 Konig Tantrums
215/45 Pirelli P7000 Supersport
Not lowered and no rubbing
Plans are to lower on Eibach/Koni, lowest perch up front, middle in back.
+40
Here is a picture of it (Mine is the sedan and the coupe belongs to jcbmrtn):
1 - 11 of 11 Posts
