Whats the proper way to check engine oil and tranny oil for 91 Coupe LS Automatic?
thanks
thanks
Everytime I go to fill up the gas, I fill up, go pay and come back to my car, then check the oil. This gives it time to settle back into the crankcase. The car has to be turned off and has to be on a level surface. You take the dipstick out, wipe it off, and then re-insert it all the way. When you take it out, if the level is between the 2 lines, you are ok. If it is at the bottom, that means you are down a litre.Thai-91Legend said:Whats the proper way to check engine oil and tranny oil for 91 Coupe LS Automatic?
thanks
Very True....especially with synthetic oil as it likes to stick to the metal surfaces better and it takes longer to settle.Roger said:you should let the car sit for 15-20 min then check it for the most accurate reading
