Sorry if this has been answered before, but I couldn't find it doing a search. Can somebody tell me the offset and/or backspacing on a stock '91 15" legend wheel? Also, will a 16" TL wheel fit nicely on a legend, and if so, what are the specs on those wheels?
In fact, any advice on 16" wheels for my legend would be great!
Thanks in advance,
Jim
*r**h *eller
Stock offset is +65MM. TL wheels will fit if you open the hub bore to 70.1MM. Best fit fot 16" are teh GS wheels. May take a while to find a decent set.
Thanks in advance,
Jim
Yeah TL wheels won't be a direct fit. You need to bore the center hub hole of the rims from 64mm to 70.1mm. Then they'll fit nicely without any problems.
cost of boring is about $100-$150 for a set of rims, depending on where you live.
Re: Re: wheels!
If I don't mind opening the hole, are the TL wheels the right offset to fit nicely on a Legend?
Re: Re: Re: wheels!
Offset is not a problem, offset is about +55 or 65 I don't remember which. It's close to the +65 that our Legends use.
