Where are the all the coolant hoses???
1K views 3 replies 3 participants last post by  stir_fry_boy
hey i was wondering if anyone could tell me exactly where all the coolant hoses are :confused: b/c i am trying to replace all the hoses since 2 hoses recently bursted on me on two seperate occasions so i figured why not change them all since there are about 15 yrs old
#2 ·
There are several.
3 heater hoses and heater control valve. Located behind the engine next to the fire wall.
2 bypass hoses that connect to the drivers side cylinder head and fast idle valve on the intake manifold. They are small hoses and are a real pain in the rear to change.
2 throttle body bypass hoses
2 differential cooler hoses. The one that goes into the lower engine block is a futher mucker to get to.
You may have an oil cooler and there are the hoses that connect it to the water pump and y together to the differential cooler lines.
You have the regular upper and lower radiator hoses as well.
I dont have a pic for any of this, but this should help...
#3 ·
ok i got the 3 coolant hoses by the throttle body, the 3 hoses located by the power steering pump the 2 transmission hoses that go to radiator under the car and the upper and lower hoses for the radiator BUT WHERE exactly ARE THE " 3 heater hoses and heater control valve. Located behind the engine next to the fire wall." could anybody show me some pics of it... i am kind of new to this.
oh and where are the oil cooler hoses as well if there are any
#4 ·
It is right behind the EGR, do a search for the EGR valve and you should pull up some pics of the 3 hoses located on the firewall They circulate coolant from the engine to the evap core and back and the fittings are through the firewall on the passenger side. you cant miss them. Good luck with changing the those as they go (#1) from the left head to the heater valve, (#2) from the valve to the firewall i.e. easiest to change and shortest, (#3) from the firewall to underneath the intake manifold which is the hardest by far because it is underneath the EGR pipe and the biggest PITA that I have ever done. throw the clamps away because once you get them off, they are harder to put on, get the screw down kind as you can use a rachet and a long extension to tighten them up if not a screwdriver. It isn't hard to miss the hoses I believe are 5/8" and they are also a PITA to change too, I know I did them. Transmission cooling hoses carry transmission fluid, and you will see red or brown right underneath the front of the bumper, not coolant (at least in a manual) if they are leaking and the differential cooling hoses carry coolant. (one located at the bottom of the differential).
