Excellent. Thank you very much.LegendGS said:It's best seen from behind the front passenger side tire. If you crawl under the car looking from the front, you will likely spot the differential before the transmission drain. Don't confuse the two while under there.
Look from behind the passenger side tire, and you should see it quite readily. You will need a 1/2" (I think) ratchet (without socket) to remove it.)
