1 - 2 of 2 Posts
Where is the cheapest place to buy H&R Springs? and what alignment kit should I get??
and im planning on buying 18x8 rims and i was wondering if i am going to have problems with tire rubbing?
502MotorSports.com
FYI
I highly suggest you go for an 18 x 7.5 max to avoid scrubbing, and to be honest, you will need a minimum of a +42mm offset. Optimal is +45mm and higher, but those are kind of hard to find these days (most are in low 40's) unless custom made. Go for 225/40 rubber as well.
H & R and Koni's will be the route you may want to go.
For camber kits, it is the Ingall's 3555 or 3557
http://www.ingallseng.com/cars/acura.html
1 - 2 of 2 Posts
