Acura-legend.com banner
1 - 20 of 32 Posts
Lowering springs will give you a stiffer car and more control over body roll, but if you're on stock (presumably old) shocks, they'll make for a very bouncy ride and poor handling on bumpy surfaces. And if you don't change out your stock shocks, they'll eventually give out because the stiff springs put extra stress on them. Once the shocks go, the car will ride like crap. But there are soft sets available that will not stress your shocks as much. I don't know what those brands are, though.
A coil-over kit is usually a matched set of springs and shocks... so the shocks will not be
over-stressed by the spring stiffness. They're usually adjustable for ride height and shock damping, too. If you buy it at a good place and the installer knows what he's doing, it'll ride better than stock while giving you much more control and better handling than just a set of lowering springs. Only downsides is possible suspension noise and rust on the grooves for the rings used to adjust height. If it's a good brand, the springs and shocks will probably live longer than your car will... as most of these sets are a hell of a lot stronger than stock suspensions... Unfortunately, they cost a freaking arm and a leg (say...$1100-$1450... or more for the more adjustable ones).
I guess it depends if you're looking for auto parts for racing or street use. I suggest lowering springs if you intend to use your car for daily street use.
If you don't want to worry about cost and adjustability and stiffer ride, then you may want to get some lowering springs. They can lower your car about 2.5" They have a higher spring rate, and are usually designed to be used with stock shocks, so the spring rates are usually not aggressive. I recommend a performance shock to go with lowering springs to make sure you get the maximum benefit and only have to do the labor once.
Discussion Starter #5
and the coilovers? there are a lot of different brands in the market and they don't come cheap. :(:rolleyes:
Yeah and there are different types of coilovers. They're available in a lot of autoparts store. some online stores claim they do price maatching but i guess they still sell them for over a 1000bucks.:wtf:
The Sleeve type is designed to be less expensive, but give you the flexibility to use the shocks of your choice.Many customers go with an adjustable performance shock or non adjustable which we don't recommend.:yes:
Fut RIP
A lot of what your saying isn't correct.
Fut RIP
Fut RIP
This will also depend on what car you have.
Drag coilovers are for those who strictly drag race. These come in either only the rear set, or all 4. However, the rears are set exceptionally stiff to keep the car from shifting weight to the rear wheels during launch. This is usually used on front wheel drive cars that want to keep the front wheels planted to the ground as much as possible to maintain traction.
Fut RIP
Any manufacturers you can suggest? I did some research of coilovers under $1K and I bumped into Yellow Speed Racing Suspension. Any thoughts?
Ok what year car do you have and is it a sedan or a coupe?
Fut RIP
He asked what lowering not what racing your going off topic.
Fut RIP
Sedan 20008 acura tsx
See most answer above are base on legend info. This is why I wanted to know what car you had. If you just want coil overs don't waste your money on a lot of off brands I'd do more looking but I can tell you this ksports and d2 are gonna be some of the best you can buy for your car. But they aren't cheap I'd save up and grab a set.
straightkid6633:
You know Yellow Speed Racing Suspension? I heard they sell high quality products at a very low cost. I wonder if you know their website? I would really want to inquire for my car. Please post it here. Thank you. :)
Fut RIP
Also try our sister site Acura world as they are way more active on tsx and other acuras as this is mainly a legend site plus try Acura planet you will love the feedback from there.
1 - 20 of 32 Posts
