Whose HID's are these?
917 Views 12 Replies 9 Participants Last post by  CakeDaddy
I have to buy some of these!!! Seeing how great the beam pattern is makes me want them even more! By the way is that a Cashmere coupe?
1 - 13 of 13 Posts
also...how did you install them? Where did you mount the ballasts? As far as hooking up the ballasts to the exisiting wires how did you connect them with the protective cover in the way? Any pics of install? Thanx...
Re: Re: Whose HID's are these?
G Rahn said:
You'd have no way of knowing coupe from sedan from the pic, and it looks like Desert Mist to me...:cool:
Guy, is that you?! Whoa, where've you been!? it's been a loooooooong time since I've seen you around.
the car is custom painted silver coupe.
coupe because of the way the turn signal light is so long.
you also know it's a coupe because of the side view mirrors :D
If you like those HID's you would probably like the Sylvania 7000k HID even more that is on the left in this picture. They have a lot better light output than those K2 8000K bulbs because they are a 7000K bulb which already has better output and plus they aren't coated (which takes away light).
Excuse me guys. How the hek would we be able to tell what kind of HIDs are in the pic from a shot of the headlight? I mean, am I just so unskilled that I think it could be just a pair of Nokya's or other aftermarket bulbs with Xenon gas in them?
I mention Nokya because that is what I have finally settled on after try 3 different Xenon gas filled bulbs. Also GoldenCoupe, you might want to think about the money you would be spending on a real the conversion. Its cheaper to find some Xenon bulbs and Polishing your headlights http://www.legend-forum.com/showthread.php?s=&threadid=1888 Your beam pattern won't be as defined as a true conversion but you should see a dramatic improvement. :)
You can tell a Sedan from a coupe just from that headlight pic. The coupe has a longer and skiny corner lense where as the sedan is short and fat.
Any suggestion on what kind of Xenon to go with??
We can tell because the member (91bulldog) posted this pic and told us what kind of HID it is.:)
sup people,
who's looking for me...
bro, i love my xenon and my coupe is silver stone metallic. Same exact color as the honda s2000.
They look like a brand called "Orsam"
Take a look a Dawks white coupe. He has the same look. I THINK!!;)
He has new post in the Gallery of his car. A white coupe with the Kahmari kit.
1 - 13 of 13 Posts
