x_y_of_z_posts
0000$$$$0000####0000
x_posts
Re: what?
tnelson said:
I have an L sedan and it has the bose system.
I think that it should fit the L as well
No, the BOSE system in the L is not the same as the BOSE system in the LS/GS. The BOSE system in the L has no accomadation for the outboard ampliflier found on the LS/GS system. L BOSE system is a model 2200 syste, while the LS/GS syste, is a 2100 system.
x_posts
What's with the model #s 2100/2200 is there any specific reason why these numbers are used... ?
I noticed there is an equalizer I believe on the non-BOSE editions?
Premium Member
x_posts
that is correct, and those units have built in amplifiers and can be used in some other honda's with the double DIN opening.
x_posts
The reason why BOSE labled each deck differently is because they are different headunits. They look the same but are not. The 2200 L BOSE system is a 80W receiver system. It was the amplifier section built in the headunit. The LS/GS 2100 BOSE system is a tunner only, and uses a separate 200W amp located behind the rear seat.
x_y_of_z_posts
