it would not be worth it in my opinion. You would have to machine the knuckle to fit the slightly larger bearings to fit the hub with the 5 bolts, then the axle shafts would have to be changed to fit the hub also, then you would have to change the the whole drive train to fit the axles that fit the hubs, after that the rest of the suspension, then the whole front part of the car since you just put the whole drive train in there and they use completely different mounts. you might just want to buy a g2 instead. Ofcoarse this is just my opinion. OR you could could go to a machine shop with a hub and have them custom make you 2 for the front and 2 for the back. Oh don't forget to change the spare to a 5 bolt also, you know, square peg round hole. Good luck!!!
