Will these rims fit my acura legend 94 sedan
1286 Views 3 Replies 2 Participants Last post by  BIGBOY
Offset: 40 Rim Brand: Effect wheels
Rim Diameter: 17 Number of Bolts: 5
Hub Bore: 73.1 Bolt Pattern: 5x114.3
Rim Width: 7.5 Rim Structure: One Piece
or these that I really like
Model - Defuse
Size- 17 "x 7 "
Bolt Pattern
5x100 / 5x114.3
Offset +40mm
yes, they will need hubcentric rings though.
where do you get these from
Where can I get these from and what is the purpose of them. Thanks for the info
our hub is 70.1 mm those wheels have a larger hub bore so the hubcentric ring will make sure the wheel is perfectly centered/balanced.
I have a extra set or you can buy them off ebay.
