61 - 67 of 67 Posts
Ok, I've read every post on this thread and I still didn't get an answer to my question. My DS/F window is the ONLY window that's NOT working and my safety lock switch on/off button is in place and working. I'm wondering if the masterswitch can be fixed, and if so how? Thanks.
I have a 94. My driver side window keeps rolling up all by itself. I'll roll it down, drive a short while and then it just rolls up and even after it rolls up it continues to keep trying to go up. I know it's a bad connection somewhere. I've seen another person ask for instructions on removing the door panel, every time I screw around with interior pieces I end up breaking them. Help please!
A 15yr O.G. Owner!
Read this whole thread, I sure like that foil fix. Need to know how much and what size of foil to be used? Do you roll it like a spliff (sorry, just keepin it real here) and jam it in the slot where the rocker switch used to be?
All windows work in my 1999 Acura RL EXCEPT for the front passanger window. I replaced the regulator and the switch, but still no power. When I attempt from the drivers side I hear the switch click, but that's it. I tested both the old switch and old regulator on the passenger back window and both are functional. Any suggestions??? Thanks.
It Worked!
I was reading articles on the forum during a graveyard shift, and came across this one.
My drivers window and sunroof were the only working windows in my car since i bought it. I got used to it... then i got tired of them not working.
I tried checking the contacts on the b-pillars and they were clean as new.
then once i found this forum i immediately tried the foil trick. it worked like a charm (back windows and drivers window all work) then i realized my passenger front window was still not working. so i checked the fuses and sure enough there wasn't one in there, i put a fuse in and BOOM! All of my windows work no problem. All thanks to the genius that posted this diy fix! I am ready for summer now!!!
61 - 67 of 67 Posts
