If it's done right, with patience and care it can be removed, or you might need a new car everytime you have to replace a windshield. Silicone sucks and I wouldn't trust it.Window-Weld for the trim? Wouldn't want to have to pull that window out again?
+1. Do it right and don't worry about it again. I also replaced the foam insulation strip (#2) & spacers (#3) when I replaced mine. Fits like OEM.If it's done right, with patience and care it can be removed, or you might need a new car everytime you have to replace a windshield. Silicone sucks and I wouldn't trust it.
I would perfer to use the clips, it's not that outragiously priced either, but the man asked about adhesive. What I would use the window weld for(as far as the trim goes) is to make a new seal for the left and right windshield trim, since acura only sells the complete trim which is a bit expensive for just needing the seal. I've been thinking about this for a bit know but like always I have more plans and ideas then time or $. I was thinking of buying some mold release liquid from McMaster Carr and apply it to the glass and body, fill the trim with the windoweld to about where the stock seals were, then place it back on the car and clean up the sides as if applying silicone on a bath tub. Then let it dry real good and remove, now just put on the clips and attach. Hopefully my plans for the seals will work, cause then it's off to other seal repair plans.I can understand the reason for wanting to use the 3m Stuff, Acura really rapes you on the cost of those crappy window trim clips!
Wow 3x, if both sides, that's like $1000.00 in trim. Isn't that always the case though, ask NY governor he spent like $3000.00 on trim. LOLAre you talking about the rubber seal that's part of the trim piece? I feel ya on that. $170 a side is no joke. I've had to replace it 3 times on my Sedan. Window-Weld should work for your idea. +1 for you.
:rofl: :rofl: :rofl: Yes, but he got $4300 trim. Per shot. Damn. That's almost as bad as the FIA president, Max Mosley, hiring 5 prosties for a cool $5000 and having them dress up in Nazi costumes and spank him. Eurotrash FTL.Wow 3x, if both sides, that's like $1000.00 in trim. Isn't that always the case though, ask NY governor he spent like $3000.00 on trim. LOL
btw, yes I was referring to the seals you stated.
