1 - 20 of 31 Posts
The Good:
325 HP!!! (Dyno'd 252hp @ wheels)
Complete custom turbo setup including:
Garrett T04E-trim Turbocharger- ~$1200
Garrett Front Mount Intercooler- ~ $800
Tial 40mm Wastegate (set at 8psi)- ~$400
HKS Single Blow off Valve- $250
RC 720cc Injectors- ~$600
Custom Fuel Rails- ~$200
Custom Honed Intake Manifold- ~$250
Powdercoated Valve Covers (black)- ~$200
SDS EFI Stand Alone Engine Management System- ~$1500
Walbro 255 Lph Fuel Pump- ~$250
Fuel lines you can fit your finger inside of- ~$200
Aeromotive FPR/ fuel filter- ~$225
RPS stage 5 Clutch (Custom)- ~$975
Flex-a-Lite Cooling Fans- ~$450
3" Turbo back Exhaust, no cat- ~$750
Turbo plumbing from exh. mani's to turbo- ~$650
Intercooler piping- ~$500
Intake piping and filter- ~$150
Optima Battery, trunk mounted- ~$150
Brembo Front cross-drilled rotors- ~$250
KYB GR-2 shocks- ~$250
Eibach Springs- ~$250
Acura CL 5 spoke rims- ~$500
Custom Fiberglass Hood- ~$1000
Kenwood Stereo and speakers- ~$500
Python pager alarm system- ~$850
Can spin the tires on a wet freeway at 80mph.
The Bad:
Salvage Title/ was in wreck
Hood and right fender are primered
Burns a little oil
Rear bushings creak
Tranny may be losing 5th gear synchro
Problem in fuse box (fuel guage, tach, rear defrost, temp guage)
Rust on trunk lip
No Catalytic Converter
Alternator? Car runs, but reports only 11.5 volts, battery never dies.
But Wait, There's More!
Included is 80% of what's needed to build a 500HP motor.
Block: Magna Fluxed, powdercoated, cylinder lined/honed, decked- ~$500
Heads: Port/Polished, flow benched, oversized valves, high rev springs- ~$1600
Crower Connecting Rods (Custom)- ~$1350
Ross Racing Pistons and Rings (Custom)- ~$950
Correct size Main Bearings (No listed application fits proper)- ~$200
Turbo Grind Camshafts- ~$250
Total of $27,150 in parts listed above, and over 100 hours of labor at $70/hr. I don't really want to sell, but I have too many cars/projects and need something for a daily driver. I would ideally like to get half of what I have invested, but I am just feeling out if there is any interest.
http://pg.photos.yahoo.com/ph/trtod...=&.done=http://photos.yahoo.com/ph//my_photos
Hopefully that link works.
Tyler
Discussion Starter · #8 ·
I can scan the dyno sheet, but will need to bring it to work from home on Monday. I have not taken it to the track and don't have any 1/4 mile times. I can also take some more pictures over the weekend. The car has 3 coil packs which run off of a crank trigger system, all managed by the SDS engine management system. The engine from the Accord is a C27A4, ours an A1. The intake manifold doesn't have the Honda placard on it, maybe the reason it looks different.
Tyler
thats not the OEM legend intake manifold. on the c27a1 under the cover is a chamber with a pcv valve, yours just has a flat surface.
Tyler
I have never seen a C27 anything with the mods you have listed. Why did you switch to the C27A4? I am guessing you are running an automatic, especially with that 23% HP loss before the wheels.
Later!
Lee
I always thought the PCV valve was on the front valve cover. You take out the two bolts and find a chamber with some oil in it. Once you clean that up you take the valve out of the bottom. I hope this is right. If not I have missed something.
Later!
Lee
· Blk/BlkGS6
lgndrcr said:
The Good:
Tyler
Nice to see another turbo Legend.
No offense but some of the parts sell new for less than half of the prices you listed. Not custom parts but the universal parts.
A stock motor is capable of the numbers posted. A motor with forged internals, built heads, engine management, fuel system, would be capable of making alot more. How much boost are you running, and why aren't you running it at higher power?
Could you post a video of the car?
hey, if you just want to sell the tubo off it hit me up!!! :) i doubt you would though...
yea, the pcv is on the front, it just the front one runs into the top of the manifold under the plate, sorry, just reverse of what i said
is it the entire system? how much? ive heard of them for sale for like 4k but i aint got that kind of money, i could build one myself for less than a grand.. i'd also be interested in just the piping, intercooler and BOV for it already set up for a legend to save me the hassle. would you be willing to sell individual parts? if so how much, and how much for the turbo? dont really expect you to give me an exact figure off the top of your head, but a estimate will do.
its really worth alot more than it is to me since i could build my own so it might not be practicle to sell it to me, im just considering how much the convienience of getting a prebuilt one is worth, so thats why im asking you about just the prewelded piping, so yea, just give me a price and ill see what i can do.
Discussion Starter · #18 ·
1)thats not the OEM legend intake manifold- It is OEM in the aspect that Honda built it originally for this car. It has been modified internally (butterflies removed) and externally. I believe the valve was removed and aluminum was welded in and milled flat.
2)Why did you switch to the C27A4? I am guessing you are running an automatic, especially with that 23% HP loss before the wheels.- Not an A4, A1. 325 hp may be a little high, I'll go with 305. Manual Tranny.
3)No offense but some of the parts sell new for less than half of the prices you listed- I've been building the car since 2000, been complete for 2 years now. Prices have dropped on many items since. Yes, it does hurt to see I spent so much money, but you can't stop halfway through.
4)How much boost are you running, and why aren't you running it at higher power?- 8psi, nice and safe for a stock motor. Built motor should be able to handle 20psi, no more due to floating cylinders.
5)Could you post a video of the car?- sorry, no video as of yet.
6)hey, if you just want to sell the tubo off it hit me up!!! i doubt you would though...- not quite that easy, it all works as a team. Lots of modification to the entire engine bay; battery must be moved, radiator is modified to squeeze in the intake tube, crossmember must be modified, and oh yah, no a/c or cruise....who needs it.
6)i could build one myself for less than a grand..- you could try. There is so much more involved than you can imagine. I had an original budget of 5 grand, but like I said above, you can't stop halfway through.
I'll try to get some more pictures posted this weekend, have to give it a wash first though!!!
Tyler
you'd be surprised how far i can stretch a budget. I just replaced a cracked piston and bent rod for less than 100$, thats parts, gaskets, fluids, everything :) i also had money left over out of that 100 to get a new intake and seat covers. :) not done yet though, got a vaccume leak around my intake manifold, so im on my way out to fix that right now, probably just needs a few more lbs on her. :)
1 - 20 of 31 Posts
